Motor Problem
PYonts
I have a 2000 40HP Johnson 2 stroke with VR02 Oil Fuel Pump. When I put it in gear and go to WOT, it will run for about 15 seconds and then shuts down. I have rebuilt carb's, put a new inline filter. No change. I took the VR02 pump off and the pulse limiter fitting at the pump has no opening.
Can you give me some help? Something else that I could try.
I would appreciate the help.
Thank you
