Motor mounts frames
solar7647
I have had a new 4.3L fall into my lap!:D So I will be replacing my 3.7L....yes the one I just rebuilt last winter (for anyone who remembers) I have yet to decide weather to strip the 3.7 and sell as parts as a hole package......but anyways the reason I am posting is I am trying to find the best/simplest way to build the frames the motor mounts will sit on in the boat. The 3.7 is a single front mount and the 4.3 has side mounts.
Does anyone have any suggestions on the best way to complete this?
Thanks
drewpster
Re: Motor mounts frames
2, 2x4 hardwood boards laminated together or 2x4 demesional lumber , round over all the edges, put them on their side and glass them in to the hull.
Temporarily mount the engine and rest it on boards or hang it from a hoist so you can measure what size pieces you need.
oops!
plus one on what drewp said.
there are variables.....
get your motor mounts and isolators first....!!!!
dont know if any came with the motor....
measure crank shaft centerline from the out drive hole.
then take an approx mount/isolator height compaired to the crank shaft centerline on your motor.
this will give you the height of your motor timbers.
in the link below.....there is a detailed over built motor cage/timber mount in the thread...use the index.
cheers
oops
Ayuh,... Along the lines of what Oops is sayin',...
I hang the motor, in place, with the rear motor mount bolts, in place, on a crane,...
Then stuff the alignment bar in through the gimbel bearing...
Then you can measure Exactly where the new wooden mounts need to be..
For the wooden mounting blocks,... I fab/ laminate up scraps of plywood...
No reason to get fancy, 'n most hardwoods Rot to quickly...
drewpster
Ayuh,... I fab/ laminate up scraps of plywood...
True, even better.
Dont forget to post pictures so we can all grade your work. Kidding.....I'm just nosey.
solar7647
Thanks guys! I dont have the use of the barn i did last winter so this project is waiting for spring, but you guys really gave me a head start so I can line up everything I will need so the jobs goes smooth.
I will be sure to post plenty of photos when the job gets under way! With the way I do thing I will more then likly find some mod to make to something! They may be hard this time since i already made all the mods I wanted in the rebuild!
Thanks Again!
