Jeff Cardinal
Thread starter- Joined
- Nov 5, 2003
- 2
I have a 1972 3 cyl 65 hp evinrude with a broken motor mount bracket. I want to disassemble it & have the pieces welded back together. the chilton manual doesn't cover this part. How do you extract the horizontal pivot shaft? the shaft has threads that stick out the starboard side about an inch. I tried jamming 2 nuts together on the threads but I couldn't get the shaft to turn, it just made the nuts slip no matter how tight i jammed them together. Is there a hidden lock pin somewhere? how do I remove it? thank you
