Bensalvage
Thread starter- Joined
- Aug 11, 2008
- 5
I have a '75 40HP evinrude that is driving me nuts! It won't idle, it just dies. If you keep it just above idle it sounds like its miss firing, it just spits and kicks. The top end is fine, runs pretty smooth but I have a feeling it could run better. This is what I have tried so far- correct new plugs gapped at .030 - pulled the flywheel and set the points which were basically fine to begin with - took apart the carb and sprayed everything I could think of - toyed with the mixture setting - fixed a switch that wasn't working which is located under the flywheel and is depressed when the motor is running at slow speeds only, (not sure what thats purpose was but it made the motor run a whole lot better at slow speeds then it did when I got it). The spark jumps about 1/2" thick and blue, fuel pump kicks out fuel in spurts while cranking the engine. Thats all I know, I'm stumped. Any help would be greatly appreciated!
