Motor issue
hvluve
My Outboard Going 5mph @ Full Throttle??
Try with new prop problem still exist. Can someone pls help?? :confused:
MacDaddy21
Re: 70HP Mercury Force Outboard Motor - Going 5mph @ Full Throttle??
might be a spun prop hub if everything in your fuel system is solid
luckynickles
Checked the following and everything is fine.
Fuel pump - fine
Spark - fine
Compressor - fine
Lower gear - fine
Carb - has been rebuild
if your motor is not reving up its not the prop you have the same problem i have
MacDaddy21
He said nothing about the motor failing to rev. He said it was going 5mph at WOT. If his fuel system is rebuilt it could be a spun hub, or the carbs might not be synced properly. Idle mixture could be off. I'd check the prop and do a link and sync. Get a manual if you dont have one.
JB
rpm???
hvluve
Not sure how to check for rpm on this boat since it does not have gauge.
