Motor in or out of gear?
fire831
When your towing your boat, do you put the motor in gear or leave it out? I was told once that it's best to put it in gear so the prop won't be spinning while your going down the road. I have also been told though it is not good to shift the motor in and out of gear while it's not running. ???
lmannyr
Master Chief Petty Officer
Re: Motor in or out of gear?
I've never heard anything about this subject before. I'll say though a spinning prop that is not in gear, is neutral. I know I stated the obvious but the prop is just spinning without meshing.
Thats sounds confusing anyhow, I'll bet that most of us do NOT put the drives in gear to tow. For those that have a malfunctioning safety neutral switch, placing it in gear could pose a hazard.
Just my thoughts.
TilliamWe
Banned
Out of gear. Why in the world would it hurt a prop to turn in the wind? And have you ever followed a towed boat before? The prop doesn't turn.
Whoever told you to put it in gear is a fool who is easily B.S.'ed. Does he want to buy a great van I have for sale? Only $2000 and it's a peach!
Oh wait, I just realized who you are. Did one of the brilliant minds at boatingabc tell you that? Was it Admin, or GFC, or FLB, or Wet Dogggg?
You should not shift an outdrive into gear while it's not running. Especially a Volvo or a Bravo series.
You are overthinking this one. Just tow it!
fire831
Never heard of boatingabc, just a simple question, thanks for the replies.
redone4x4
neutral has been working fine for us for 17 years now.....
109jb
First of all, I run outboards. I generally leave them in neutral, but I had a boat that the trailering cover would not go on unless the throttle lever was put forward. I never had a problem either way in many many years.
nimmor
On an outboard it is not good to shift without the motor running, it can break the u shaped horseshoe on the gears. I am curious what is boatingabc?
kenmyfam
Out of gear has worked for me so far but I am prepared to be educated otherwise.
TilliamWe
Banned
And on a Bravo or a Volvo drive, shifting into gear without the engine running doesn't allow the cone clutches to function properly. You can actually get them stuck in gear if you do it. So don't.
Kenny, no education needed, leave the drive (or outboard) in neutral. Even if the prop spun around like those plastic hitch covers you all have (which they don't), remember, your outdrive (or outboard lower unit) is full of gear oil, thus lubricating the gears and everything, even while the motor is not running. Plus, the wind couldn't possibly spin your prop anywhere near as fast as the motor does, when in gear on the water.
boatingabc is a website that has a forum page, where there are some good guys and some know-it-alls. A LOT LESS techinical expertise on there than here on iboats. So if you want to talk about sports and cars and financial news and such, they are good to talk to. If you want to know about boats, and how to fix them, this is the place to be.
TilliamWe
Banned
Sorry, my mistake, your screen name is very similiar to someone's on there, who is also from Indiana. And leaving the drive in gear sounds like something that one of the less educated, more gullible members on that page would pass off as gospel.
Edmac
I believe this info probably came from the Mercury Owners Manual, mine
states on page 34 under the instructions for trailering "Shift the outboard
into forward gear. This prevents the propeller from spinning freely."
Also, on page 52 of said manual it states "Do not shift outboard into
reverse when the engine is not running."
The way I do this on my 150 Optimax is when I load the boat on the
trailer, I just leave it in forward gear and turn the key off.
MudSkunk
airflow really doesnt provide enough resistance to spin a boat prop while traveling at speed. when you are at anchor in a current the prop will turn slowly but there is harm going to happen to it. just notice the next time your ont he road and see someone towing your never going to see the prop spinning like a windmill.
TilliamWe
Banned
Then it's official, someone at Mercury Marine is an idiot! Seriously, what a STUPID thing to put in the manual.
Mudskunk sees what I see, props don't spin on trailered boats. They just don't.
Splat
Likewise on my 1995 25hp Merc the manual says to leave it in gear. I have been doing it like that for many years now, now problem. Never really thought about it before.
BIll
kenmyfam
I actually followed a boat on my drive to work this morning. At 80 kph (50 mph) the prop was turning really slowly. First time I have ever seen it.
quackaddict1
I saw the same thing tonight, looked like a 50hp class motor, prop a spinning in the wind.
I wouldn't worry about it though, if anything I think the boys at Mercury are more worried about distracting people behind you than damage.
SS140
Banned
I could picture stoners getting lost in the twirl of the spinning prop. ALL THE COLORS! LIKE A RAINBOW!
Fl_Richard
Maybe we dont see them spinning because everyone else has theirs in gear....
(I'm a spinner)
tmcalavy
I trailer both my late-50s OMC Big Twins in N, prop spinning...helps the overall mpg on the road...gives me a little passing umph, too.
