Motor ID
Gamecock
Re: Motor ID
not sure of the model #...does that mean i cant be helped?
Bear
Re: Motor ID
Johnson 18 hp model numbers 1957 -1965: <br />FD-11 is a 1957, FD-12 1958... FD-19 is a 1965<br />If there is an L (FDL-**) you have a long shaft <br />Also check the powerhead for a plug with the model number stamped.
biloxiriver
Re: Motor ID
The freeze plug, if original, should have the model and serial number on it. Note - sometimes folks paint over these, just scrape it off.
