a70eliminator
Thread starter- Joined
- Sep 9, 2007
- 3,762
Hi again, I never payed much attention to motor height until now as i just hung the replacement for my piston scored 60hp, I used all the cosmetics from the 60hp including the longshaft leg, cowling ect, an 80hp powerhead now hides behind the 60sportfour cowling and badges.
Do you think the cav. plate is too far below the hull? If I can safely raise it some it would be a good move as I fish alot from this boat and hitting something in shallow water is one of my biggest fears not to mention maybe there would be a performance gain in there too.
Just a side note: I notice alot of play in the motor mount, the top pin of the transom clamps fits loosely into the motor mount and I think thats where the play comes from? Is this normal, that little pin sure has a big job to do especially if I raise to the next notch as the motor will no longer be resting on the top transom cap.
Ok forget all that stuff and go to the last reply which is where I'm at now.
