samo_ott
Thread starter- Joined
- Jun 18, 2006
- 5,125
I have an old Johnson 25 on a light peterborough cedar strip boat. It's new to me. After getting the engine up and running it seems there are motor/boat matching issues. It has what feels like a spun prop but I changed it with another and get the same symptoms. At around half throttle it feels like it's slipping, like a clutch slipping in a car. The engine revs more but the boat slows slightly. It looks to me like the motor is too high on the boat. The transom measured at around 17.5 inches on the diagonal, not vertical. The cav plate just above the prop is around flush with the bottom but that leaves the prop less than inch below the waterline at speed, is this a proper set up?
Also when around half throttle the bow dips a bit and starts plowing in the water creating big splashing around the front hull. The tilt pin is out all the way and I even tried some shims to tilt it more to see if it would help but it made it worse. I'm considering cutting/lowering my transom by about 1.5" but do not know if it will help. Any comments please?
p.s due to the angle of the picture it looks like the cav plate is below the bottom of the boat but it is not.
p.p.s. as you can also see the static water level (stain) is just above the water pump bulge and seems to be too high also.
p.p.p.s. I did not paint it black!
