motor guide wireless w55 12 volt
chepe mesa
Si en el foro existe alguna persona que hable espa?ol y me pueda ayudar.
Estoy en colombia y no tengo forma de pedir la garantia.
El dia de ayer me encontraba pescando y la prop de mi motor electrico se enrredo con unas matas. Al quirarle las matas el motor quedo prendido no apaga no gira no cambia de velocidad.
Quiero saber si existe una forma de arreglarlo o que puede estar pasando.
gracias
Bob_VT
Re: motor guide wireless w55 12 volt
Quiero sabersi existe una forma de arreglarlo o que puede estar pasando.
gracias
Translated via Google.
If the forum there is someone who speaks Spanish and can help me.
I'm in Colombia and I have no way of asking the warranty.
Yesterday I was fishing and my electric motor prop is lack of focus with some bushes. Quire the plants to stay turned on the engine will not turn off no speed does not change.
Let me know if there is a way to fix or can be happening. thanks.
Bienvenido a iboats! Espero poder encontrar a alguien que pueda ayudar.
(Welcome to iboats! I hope I can find someone who can help.)
The translation seem to work well, but the question is alittle difficult to understand.
Hopefully someone can decipher the question. :confused:
Su pregunta es un poco dif?cil de entender, quiz?s tratar de describir el a?o, marca y modelo de su motor y lo que es el problema y podemos tratar de ayudarle.
Aqu? hay un enlace a la traducci?n gratuita de Google que te ayudar? a traducir sus preguntas a nosotros en Ingl?s. ;)
http://translate.google.com/translate_t#
eavega
gracias
If someone in this forum speaks Spanish and can help me.
I am in Columbia and I have no way of requesting the warranty
Yesterday I was fishing and the prop on my electric motor tangled in some weeds. When I cleared the prop the motor continued to run. Cant turn it off, but the prop won't spin or change speed.
I'd like to know if there is a way to fix this or if anyone knows what is going on. Thanks
eavega
Chepe
Que edad tiene el motor?
Lo que dices es quizas que esta jirando el motor, per no el Prop? Puede ser que el centro del prop se llevo su rozca. Si sigue girando el "Shaft" trata de ponerle un prop nuevo a ver si asi empieza a trabajar. Si no esta girando el shaft, entonces es posible que se halla desconectado el shaft del motor. Alli si que tiene que consultar con alguien que sepa mas de esos motores electricos, pero yo puedo traducir entre lo que pueda yo. Mi espanol no es perfecto, pero por lo menos me puedo comunicar.
Slds
Eric
