Motor goes WOT when disconnected from fuel tank?
hogg
Re: Motor goes WOT when disconnected from fuel tank?
My hat's off to you 'knowledge base' guys!
"Fuel problems, check here first" and link the (here) to the check the fuel pump first statement.
jonbellamy
I vote for all newbies to be required to check their fuel pump before posting it take 10mins and should be standard procedure, also i believe all fuel pump diaphrams are the same for 9-150hp, correct me if i'm wrong.
I wish this was standard procedure too. I posted the symptoms and was told to do coils and points first. Did that and still same issue. I didn't know that fuel pumping from back of fuel pump meant it was bad and didn't know this was a fuel issue until i discovered it would run full speed until i accidentally pulled the fuel line. As a "newbie", I didn't even know what the fuel pump was and how it worked, but now I know a bunch about my motor. I'm thankful people took the time and effort to help me.
As for fuel pump diaphragms, I don't think they make repair kits for the one i have so i'll have to buy a new one. I hope the motor runs flawlessly after this is done.
Watermann
I bet it will start easier and run like a scalded dog with a good supply of fuel. Glad you tore into the fuel pump and weren't wanting to keep trying some "easy" outside fixes like so many.
