Motor for Pontoon
mippel
Hi All,
I am looking at 18' - 20' pontoons and all that are in my range have a 25 horse motor. Is it necessary to have a motor that is designed for a pontoon? Like a bigfoot or any other one that is geared for a pontoon. Will a "normal" 50 - 60 horse work? Or will it need a motor designed for a non planing hull? Sorry if this is a stupid question, but don't want to plan to killa motor that i will up grade with. Thanks in advance. :confused:
Water logged
Re: Motor for Pontoon
It's not required to have a pontoon motor, I'm not even sure there is such a thing. A bigfoot may be more satisfactory than a standard because the gearing and size allow for a more pontoon freindly prop. The main thing is to get to correct prop for your boat motor combo.
Glenn
The Rooster
Ensign
Glenn
+1 ^^^ Mike. Good luck !!!
Old Screwball
Agree about the 'pontoon' motor. IF IT WERE ME... I'd get the biggest engine the transom is rated for. You can always go slower, but you put a 40hp motor on an 18' toon, you aren't going to go to fast.
MH Hawker
About the only thing special about a pontoon motor is it would be whats known as a long shaft, thats 20 inches from where it sits on the transon down to the bottom of the motor.
RustyShackleford
BigFoots are good because they get the prop lower in the water, but pontoons are sold without BigFoots too. My dealer said a BigFoot will move a pontoon faster than the same HP motor not being a BigFoot.
I have a 60HP BigFoot on my 22' and it moves along enough to not get bored. GPS says 17MPH with a few guys and gear. I definitely wouldn't go with anything smaller than that if you are planning to have a few people onboard.
Rancherlee
Definately go with a "Bigfoot", Yamaha F-series, All Suzuki (zooks are all geared low and swing big props). It's all about the prop size, a 14" diameter prop makes maneuvering at lower speeds/docking ALOT smoother. I had a 28spl with a small 10" prop and it took alot of throttle and time to change directions, in a slight breeze it sometimes took over 10 seconds to start moving in reverse! My 70hp with a 14" prop moves instantly when changing directions. Bigger prop also resists cavitation alot better.
Bamaman1
Like it was said, go for the larger end of horsepower your hull is rated for. The Yamaha 50-60-70 motors are virtually the same 996 cc engines. The Yamaha 75 is substantially larger @ 1566 cc's and is worth the extra weight and cost--in performance.
Little engines on full size pontoon boats will insure one thing--boredom. If I cannot run in the 20's, I cannot do a good job of outrunning storms. I prefer my boat to be seaworthy, which the larger engines give.
25 hp motors are for aluminum jon boats, where they do a good job.
86 century
Ensign
Maybe this will help you my inlaws 22' toon with a 40hp eventide will make about 11mph with 4 people.
My parents 18' with a johnson 48spl will run 22mph with just me and the little one.
They both get the job done not real fast but they have fun
