89Force85hp
Thread starter- Joined
- Aug 29, 2007
- 4
I recently purchased an 89 Bayliner with an 89 Force 85hp (856X9E) that underwent a "tune-up" at a marina two days before I purchased it. The paperwork from the marina indicated all three cylinders had good compression each around 150. I've taken the boat out twice and had a couple issues each time that bother me and I'm not sure where to start troubleshooting.
On the first trip, the engine was extremely difficult to get started the first time. Subsequent times during the day of running around were much easier. The motor ran fairly smooth as well. I did seem to find a spot during accelleration where the engine would kind of stumble a bit, but going just past brought it back. During the evening, we did some tubing. All going fine until someone fell off and it was time to kill the motor. Upon restarting, as soon as you dropped it into gear, it would die. Restart and let it idle for a minute, and drop it into gear and it would try to die, but give it a little gas and it's okay. Then when the tuber fell off again, it would go through the same thing.
On the second trip, the starting issue wasn't nearly as bad. I made sure that when squeezing the priming bulb that I almost over did it, nearly to the point I thought it would be flooded, but it wasn't. Later in the afternoon, I experienced the same issues with restarting the motor. Additionally, after restarting, I would feel a vibration and the power would not come up until I pumped the gas a little by backing off till it smoothed out and gradually increasing until I was up to speed and planed out.
At this point, I don't know where to start, fuel or electical, or both? Any experts on these 2-cycles have any advice? Thanks!
