motor cuts out when accelerating! HELP!!
fishermannate94
the motor is a 1998 Johnson 25 hp. we have rebuilt the carburetor and the fuel pump. before we did that the motor wouldn't stay running at idle but would run great when accelerating. now it idles great but as soon as I give anything more than a quarter throttle the motor starts bogging down and cutting out any help is greatly appreciated, thanks!
Will Bark
Have you done a link and sync on it? Did you get the high speed jet clean? Have you pumped the bulb when it starts bogging? Try these and see what happens. Good luck
Have you adjusted anything on the rod that goes to the back of the motor ???----Have you tried opening the LOW SPEED MIXTURE a bit richer ??
fishermannate94
hello, it has been a while lol but I am still having the same problems :( I was told by a fellow fisherman about link and sync but I don't know how to do that.... he told me he is convinced that is the problem! and yes I have adjusted the needle according to the handbook and no luck... also the carb and every component is spotless! please help me! thank you!
fishermannate94
ok I will. the only rod that I can find is the throttle linkage... but I am just a novice... thank you!
