Motor Cranks slow. Tried everything Any ideas?
Andyg101
I wanna start off by saying i haven't got the battery or starter load tested but when volt checking it, it all seems fine.
I isolated the starter and the solenoid and they both tried to turn the motor over but it was still slow cranking.
The boat motor had been winterized and sat around for a long time.
I've went over everything besides taking the motor apart and it all looks to be in relatively good shape.
I took out the plugs and isolated the starter and the solenoid, it turned the motor over perfectly fine and normal but when the plugs are in it will not crank normal, i have read everything online to no end.
I'm at a complete loss of what to do. I've replaced the cables cleaned all the connections and i'm just not sure what else it could be.
Any ideas?
Honorary Supreme Mariner
What motor you talk about ??-----Take the starter apart for inspection.
Sea Rider
Although volts could read OK, probably bat is very low on amps and not doing their homework right specially if bat sat for a long time period. Check bat amps and re charge bat if needed,..
Happy Boating
F_R
Are you doing a proper voltage check? "Proper" means a voltage drop test across each item in the circuit. That includes the ground circuit.
jakedaawg
Take the battery to local parts store if you don't have a load tester.
have battery load tested! This is step one, every time. It's free also
StarTed
The above advise seems all good to me. What is the battery voltage while cranking?
In addition I had a similar problem with my 75HP Evinrude. It turned out to be one of the starter brushes had a lead that was loose in the brush (one of the 4 brushes) and sometimes would work a little and then not. A new set of brushes solved that problem.
I connected 2 new batteries in parallel and the starter still wouldn't crank up with the spark plugs in.
Hope you find the problem.
Lightwin 3
Do the cheap stuff first.
OMC's with unregulated charging systems are notorious for corrosion under the negative battery terminal where it attaches to the engine block. Remove the cable from the block and clean both surfaces thoroughly.
clean all the cable contacts, including the starter and where the starter bolts to the block. all these contacts must be shiny enough to eat off of.
Andyg101
all seems good with the battery, its a 1982 evinrude 25hp outboard. ive checked all the connections and i think it must be the starter. i used a different battery and even tried using jumper cables. same problem. im leaning on it being the starter but ill have to take it to get tested. will update soon.
F_R
If it isn't an electrical supply problem, it is possible the permanent magnets in the starter are shattered.
Brabbtiger22
I have fixed this issue many times because I have been restoring old engines of late. First: clean all cable endings and ground wires. Sand them down. Second make sure the battery is new or like new. 3rd I am leaning toward worn out or getting worn starter. I replaced one last week for the exact same problem. It would try to turn the engine , but wasn't strong enough... Then it started to bump and pop back down at times when turning over. Bought new battery thinking it was that. Wasnt. New starter turned it like a charm. Now If everything is still the same with all that new then take the spark plugs out and spray some seafoam in there. Spin the flywheel by hand a few times. It should be easier with the spark plugs out. This will help unseize an engine if it's sticking in any areas. When cranked the seafoam will burn up and come out as alot of smoke. No worries it will clear within minutes once cranked. I did this to both of my old engines that hadn't been cranked in 10-15 years while sitting outside exposed. If anything i gained 5mph by doing this lmao. I hope this helps.
Crosbyman
..........I took out the plugs and isolated the starter and the solenoid...
are you saying you tried applying battery +12 power directly on the starter post .... bypassing the selenoid cct ......
if you did not try it (bypassing the selenoid...) give it a try it and report back
MaPaHa
I'm going to agree with the question of whether a proper voltage test was done.
Place a volt meter on the positive post of the battery (not the terminal) and the bolt where it connects to the starter (not the ring terminal). Have someone crank the engine and observe the voltage. In theory, it should be "0" volts since you're on the same line but it will have a slight voltage because of the load. But not much.
Do the same thing on the negative side from the - post on the battery to the engine block.
I helped a friend that had changed his starter a couple of times with no luck and we found the - side had 4 to 5 volts during the cranking cycle. We traced it down to a bad main battery black cable with good ends and no physical damage on the cable.
Battery voltage will drop during cranking but I want to know that: "the voltage at the battery is making it to the starter under a load", so a voltage drop test on each wire is a good way (but not the only way) to do that.
Another way would be to observe the voltage at the battery during cranking, then observe the voltage at the starter bolt and engine block ground during cranking and see if there's a difference. If so, you still have to check each side independently to see where the problem is.
Mark
