Motor Change
mike165
I have a 80's 20' tri hull,Mercruiser 165,250ci IL6, MC1 drive 1.165,all in good cond just finished a resto on the boat all going good,very happy with the boat,looking at the possibilty of a motor upgrade to a 350 SBC,I have plenty of space in the motor bay,will the same bell housing fit the 350?,and will I encounter any problems
achris
More fish than mountain goat
Re: Motor Change
Easier (and cheaper) to find a donor boat with the engine in that you want, then just swap everything across...
mike165
Re: Motor Change
I have acess to a 350 at the right price,the main ? is will the bellhousing fit
dubs283
Re: Motor Change
if you are asking if the 165 flywheel cover will fit a 350, then - no, like in post #2
the easiest way to do what you want is to swap an entire 350 engine/drive package into your boat - from pulley to prop
you will probably have to add/remove material/motor mount areas in/from your bilge too
achris
Re: Motor Change
Find a 350 in a donor boat and you won't have to worry about what will and what will not fit. Just swap, as dubs said, pulley to prop....
mike165
Re: Motor Change
Donor boats are not as easy to find in OZ as the US they do not lay around in paddocks for $100 as they do in the states
achris
Re: Motor Change
Tell me about it!!! I'm in Perth and it's no picnic for GM engine parts.
mike165
Re: Motor Change
Hi Chris,I thought you were in Perth,I have a son who is at Ocean Reef,I lived at Scarborough for 4 years in the 60's.
It would appear after speaking with Engine Master Australia in Albury the 250 Flywheel cover can be used on a 2007 350,I do not want to change the gimbal and drive as I had it all out last Winter and it is now in mint cond and I have two complete drives 1.165 &1.184,and a heap of props from 17" to 21"
Thanks for all the help
achris
Re: Motor Change
...I have two complete drives 1.165 &1.184,and a heap of props from 17" to 21"
I hope you mean 1.65:1 and 1.84:1, which are not the right ratio for a 350. The correct ratio for a 350 is 1.5:1. If it's a big heavy boat the 1.65:1 would be a good choice though...
I'm south of the river, and do most of my boating on the south side of Rottnest or travel north to the Abrolhos or Carnarvon....
Chris.......
mike165
Re: Motor Change
I hope you mean 1.65: and 1.84:1, which are not the right ratio for a 350. The correct ratio for a 350 is 1.5:1. If it's a big heavy baot the 1.65:1 would be a good choice though...
I'm south of the river, and do most of my boating on the south side of Rottnest or travel north to the ,
I knew the ratio was a bit out for the 350,we used to dive on the Abrolhos and at Carnarvon....way back!!
Chris.......
Thats what I meant
mike165
Re: Motor Change
