motor change
I would like to change out motors I have a 1984 seaswirl with a chevy 4 cyl. she is starting to cost way to much to keep running. what can replace her with ,a direct swap. have tried to locate same motor not happening.
Re: motor change
You're limited to Either a 2.5l,153cid,120hp, boat motor.....<br />Or a 3.0l, 181cid, 140hp, boat motor....<br /><br />No car motors will Swap...
anesthes
Re: motor change
Find out if your boat was available in a 5.0 or 5.7, and swap that way like I did.<br /><br />Making the stringer mounts is easy, and the swap works a charm. Just make sure your boat can deal with the weight.<br /><br />Just make sure you prop it right so your top speed MPH is within the boats capabiliies, though you'll prolly find the v8 has a similar RPM range<br />then your 4cyl. The increase in HP will give your straight line acceleration some improvement.<br /><br />-- Joe
