MonkeyBird747
- Aug 5, 2020
- 112
Upgrading from my 1985 50hp merc. I've read the boat is rated up to 125. I found a 2001 Merc 2-stroke 125hp in good shape for $5k. It's a little more than I want to spend, but it will also plug and play with my existing controls. I know 4-strokes are heavy, but have 2-stroke engine weights changed that much in 50 years that I'd worry about going up to the maximum hp rating? Would I be better off with a 90 or 115? Also a factor is only 12 gallons gas on board.
How should I inspect the transom to make sure it is in sound condition before upping the weight to 350lbs. I have no way of knowing when it was replaced last.
Cheers!
MB
Cheers!
MB
