Swampmouse
Thread starter- Joined
- Feb 2, 2007
- 121
I have a 115hp Johnson - 1983 model.
Went fishing today and it ran great for a couple miles. After my second stop it didn't want to start. After a moment I got it started and it idles in neutral, a little rough, but will idle with the throttle up a lttle bit - revs up to high RPM, but when I put it into gear - no power. The motor won't even rev all the way up when in gear - the only way I can describe it is it sounds like it's bogging down. At first I thought I spun a prop, but the motor won't rev al the way up while in gear. Had to idle all the way back to the dock.
Last week I used it for the first time in quite a while and had trouble getting it started. To get it started, I took off the carb. cover to spray in starting fluid. Once running, I didn't put the cover back on for time's sake.
Do you think maybe the carb got a small piece of trash in it that clogged the jets?
Any ideas or suggestions?
Thanks,
Sm
Thanks,
Sm
