Motor bogging down after idle
Riley1840
I have a Nissan 4 stroke Efi 30’ hp [NSF30B]. After idle thru no wake zone motor acts like it is starving for fuel, will barley come up to 2k rpm. It does this when running on on board tank.
I have cleaned tank, checked and cleaned vent, changed fuel hose and bulb. I can change to auxiliary tank and up until yesterday it would run fine. Yesterday after changing tank motor ran about 5 minutes then slowly started losing rpm. One other thing I would do w]hen on inboard tank and it would bod down was shut engine off’ for 10 seconds then then start and it would run good till next idle zone. I thought fuel pump, but need some advice. Thanks
pvanv
There is a schrader valve on the fuel rail to chk pressure. Could be the high pressure pump (FFP) or the ECU.
Riley1840
Ok will get a pressure reader from store and will repost with results. Thank you. Have also ordered high pressure fuel filter.
Riley1840
Update. Sorry for delay but had to wait on part and time to work on motor. What I did was change fuel lines on motor and put a new high pressure fuel filter on. After checking pressure at schrader valve.. motor is running very good now. Thanks for the help.
