vicpresnal
Thread starter- Joined
- Apr 13, 2011
- 23
replaced 4.3 motor, tried to mark the motor mounts, had a little trouble aligning motor to outdrive shaft when installing, may have motor out of alignment, outdrive is starting to scream and rumble a little, sounded good for the first few times out. While in neutral it is quite, only noisey when in gear. Out drive is also over due for service. could my problem be alignment or just time for gimble bearing and other maintance, approximatlely 400 hours and 11 years since complete outdrive service.
If motor is out of alignment, would that cause wear in splines on the flywheel transfer plate?or other issues in the outdrive itself.
