firefltmedic
Thread starter- Joined
- Jun 27, 2009
- 14
Does anyone know if a MOSFET switch can be taken apart and rebuilt, or will I have to switch a motorguide trolling motor over to digital?
With the right soldering equipment, they almost certainly can be rebuilt (This assumes there is not too much damage to the board, and that a similar MOSFET is available.) To be honest, the fact you are asking this question says that you probably do not have the right equipment. The right equipment will cost a minimum of $50. Then you need to know how to do electronic soldering.
TerryMSU
But have you done ELECTRONIC soldering? That said, give it a try. At a minimum you need the capability to solder with a grounded tip soldering iron. Controlled temperature would be nice. For MOSFETs, ESD (Static damage) is a big issue. High humidity and tying yourself and the unit to earth ground will help with that. Finally, unless you are using "no-clean" solder and flux I would recomend cleaning the connection with some sort of solvent (perhaps acetone) to remove flux residue. The flux residue is slightly acidic and will eventually eat the traces right off the circuit board. Remember that acetone is highly flamable, so give it quite some time before you use it to power up the motor. The brushes on the motor will set the acetone off. (Don't ask me how I know, but it was exciting.)I have plenty of equipment available to use, and have done electric soldering before. After troubleshooting the board in the top housing of motor, it tested out fine.
