As previously stated, Don, I just got this back from the shop & the trim gauge was no way adjusted right when I got it back from the shop, so now I got the gauge to read down when it is down instead of reading 1/4 up now. However it used to go up to the maximum operating range if I press only one of the up buttons. Now it does nothing unless I press both of the buttons & then it goes all the way up to the "trailer" position. When I adjust the left side sender nothing seems to change. The sensors are new too. We took this boat out for the first time last weekend since we got it back from the shop where they put in a new trim gauge, tach & electronic distributor. Now all the gauges, except the speedo read as if the ignition key is in the run position & the motor is on when off. When in the run position the gauges don't read anything until the engine is started. For example the temp gauge reads 180 when off, the oil pressure reads too, the tach reads 500 rpm. The hour meter doesn't work at all now in any key position. When we start the engine the tach fluctuates wildly up to 10000 rpm for about 15 to 30 seconds until it settles down. The boat goes 37 mph @ 3500 rpm. I think it used to rev higher than that but I forgot what wot is on this boat. I think it needs the lighter distributor springs put in it for that? This distributor came with two lighter spring sets. What do you think? How about a little help this time, Don? I didn't have any of these problems to begin with when I took it in to the shop all they did was replace the trim gauge, tach & install the distributor. This is a good shop as they said bring it back but I like to do things myself when I have time & this a good example of why I want to do it myself. I had been putting this work off for 2 years because I didn't have time to get to it. I have no idea where to start looking for these problems but want to try to fix before I take it back to them in 3 weeks. Thank you, HF.
