Re: more power
Welcome to ibaots.
I am with everyone else, you can hop up an engine but you need to have alot of knowledge about 2 strokes, an extensive garage and a thick wallet.
Faztbullit is an engine guy that can actually do all those things and if he wouldn't mess with it you shouldn't either.
As JB said just make sure your engine/boat is set up properly with the correct engine height and prop, just raising the engine to the correct height can get you some pretty good gains.
Also weight distribution can get some gains.
I have tried about everything to get my boat faster other than dinking with the engine and have found it is what it is, I got a couple MPH more and that is all she has, speed on water takes alot of power and the little bit you may get by tinker with your engine may get you 1-2 mph and is more likey to ruin your engine.
