- Mar 8, 2009
- 44,517
Have a 1994 Formula 27PC which weights in around 10K pounds (sig below). Currently has a single 502MPI and moves it OK with B3 drive. Having a few minor issues which I want to fix so while the engine is out I'm looking into increasing the HP and changing the outdrive. Reading a few threads on OSO about increasing the HP and still being able to run on 87 octane. Haxbyspeed (OSO see below) has a good thread on pumping up the 502. It did loose a bit of HP when changed to Holley fuel injection but that was top end. Currently my cruiser gets a bit loose at WOT but I need to replace my gimbal ring and pin this year. My thought is to pull the Merc MPI off and go with the Holley EFI setup. Change out the cam, install roller rockers then replace my standard B3 drive with a B3XR setup all new transom. From what I have been reading on HP rating, the X and XR have the same rating, don't know what else the differences are. I run 89 octane all the time because
More Power http://www.offshoreonly.com/forums/...tarts-me-thinking-more-power.html#post4171672
Haxbyspeed post 502 MPI upgrade http://www.offshoreonly.com/forums/do-yourself-boating-budget/248779-502-mpi-upgrade-results.html
