More on the Husqvarna rider...
Nandy
This is the epitome of southern ingenuity... apparently, the previous owner had a problem with the gas tank stem... this guy replace it with this... Lets see if anyone of you can tell....
Thanks.
Nandy
Re: More on the Husqvarna rider...
Yep! The socket... I could not believe it. It looks like it would work but the stem and seal is less than 10 together. If one is going to cut open a $80 tank at least replace it with the correct parts since they are so cheap. I would think you can make the replacement without having to open the tank if you use the oem parts.
