Cdnpokerface
Thread starter- Joined
- Nov 5, 2014
- 19
Okay first off thank you for all of the help in my other thread. I've sorted some issues out but I'm still having one I can't wrap my head around.
Here are the details
I'm using the engines in Ontario vanada so out water temp is approx 48 degrees
My starboard engine is running good the port has been giving me some issues.
My issue is it starts and idles fairly ok for a few mins then idles down low sometimes comes back to normal and then will die.
I have replaced both thermostats as they were both toast and engine was running very cold.
All carbs have been rebuilt
Compression test done all cyls between 120-125
Replaced fuel water seperator
Replaced spark plugs and coils.
Replaced voltage regulator
I have determined when I unplug coils on cyl 1 & 3 nothing changes in the way the motor runs. I have checked spark and it is bright blue and jumps 7/16 gap with no issues also the plugs on 1&4 look as tho they are sparking just not clean. I also tried swapping the plug wires between 1&3 i case something was mixed up in the cdi wiring but when I do that the engine doesn't want to start at all
The carbs are calling for fuel and getting fuel delivered when I cover the fronts of them.
The only things I haven't done is check dva values on the ignition parts yet
Any advice would be greatly appreciated
