Re: more grunt
A 235, huh? Where do I get the decals? <br />After running the rig for a week I'm noticing some other problems. There are definitely some electrical gremlins at work here. The boat is a '98 Playbouy that has been sitting for a year.<br /> The only dash gauge that moves is the tach and it arcs CCW from a 6:00 position, instead of zero, to about 6200 RPMs - even @ idle. The motor has overheated twice, so I know I'm looking at a waterpump. It also stalls occasionally when I throttle down into to neutral/ idle. This may be from some old gas left in the on-board tank - I hope!<br />Also at WOT the motor will sometimes lift out of the water. I have adjusted the trim and it still does it to some extent.<br />Looks like some serious TLC(and patience)is in order.<br />Thanks for your help for a newbie.
