more compression talk
dannyman3
does anyone really know what the stock compression is on 1990 200 gt ive heard some many diffreat things its crazy my cranking compression is #70 in each cyl, was told that was ok that running compression would be around 100psi i just want to know what the factory stock compression was on that motor the model #vj200slese hard to bleave mine is bad runs good and all 6 dead on with each other
JB
Re: more compression talk
Read this carefully, Danny:
There is no "factory" compression number.
Reason?? Guages differ, techniques differ, temperatures differ, other conditions differ.
Big OMC V6s often measure psis in the 60s-70s when in excellent condition.
Your engine is in fine condition
jonesg
The factory service manual lists no compression numbers, they need to be even thats all.
Mine tested at 30 psi, got a new guage and that showed 60 psi.
Ran some seafoam thru it and sprayed some in the cylinders, compression jumped to 85+. Runs fine anyway so...
have to go fix somethin else.
