More Compression Checking Questions
turtle1173
I do not have a compression guage. Can I by one at any auto parts store? Are there different types and varieties? What does one cost?<br /><br /> I have a 1976 55HP Chrysler. It has 1 carb and 2 cylinders. Can I just take the plug that is not being checked out but leave it hooked up to the spark plug wire? After I warm the engine up, do I need to crank the engine with the throttle wide open (but not in gear of course)? Anything else I need to know?<br /><br />Thanks <br /><br />Shane
alcan
Re: More Compression Checking Questions
Hi Turtle<br />I would think around $35. should get you a decent gauge w/hose and a couple adaptors for different sized holes. Don't get the cheep hold up to hole kind.<br />Pull both plugs, ground both spark plug leads,install gauge, open throtle, crank over 3-4 times. Record reading. Then repete on the next hole. Readings should be with in 10-15lbs of each other.
Franki
When you say ground the spark plug leads, do you mean short them to earth so that the charge goes directly to ground?<br /><br /><br />rgds<br /><br />Frank
Trent
Yes thats what he meant.
crab bait
i got the impresson that you ground them to the motor casing ( block / motor metal)
petryshyn
Franki<br /><br />Ground the plug leads directly to the block... :)
turtle1173
How are the spark plug leads grounded to the block? I'm just having a hard time picturing this, as I've never done this before.<br /><br />Shane
G DANE
Hi Turtle<br /><br />I usually put the plugs in cords and lie them on the bolts beyond coils, and they will lay there sparking.
dixieray
Why ground them? Keep high voltage off system or what just courious.
