JSGOLD
Thread starter- Joined
- Sep 22, 2009
- 609
I may have already screwed up a bit, but.....does the "boss" gasket simply slide up to the top of the tube? Ir is snug, but could be tighter on the tube....was not sure what it even did but read some of the old posts here...second- the drain plug in the carb bowl, seal it or not? If so, what with? Lastly....my "sierra" kit has a clip for the float and valve, however since my old carb did not use a clip I did not either.....a post I read advised against this....now I can't find the blasted thing....too small and hard to find. The other reason I did not attempt to use it is I see no where to clip it. The needle has a place but not the new plastic float. Did not see anywhere on the old cork one either. I have dealt with old lawnmower and mini bike carbs that used a clip but they all had places to clip to on the floats......any thoughts????? BTW I have less than good things to say about Sierra parts. I had to use the old float holder rod, as the new one would not clear the bowl area properly and not thrilled at the quality of parts. Guess on these it pays to locate OEM if possible....
