More 1956 evinrude ?'s
jonboatman
Hello all,<br />I looked further into the motor while I was cleaning it, and I found where someone did a odd thing with the fuel pump. They took a piece of 1/4 steel and mounted the pump to it, and they mounted the pump to the side of the motor over one of the plates that covers the bottom of the cylinder. They then drilled a hole in the plate, I guess so the pump would see vaccuum.<br /><br />Does anyone know where the pump should mount? The motor ran good the last time it was used, so I wonder what the deal is with this repair. I wonder if someone didn't change it to a more common pump.<br /><br />Also, the cylinders look good and there is no ring groove. How often do the rings need replacing in these type of motors? The pistons have 3 rings, is that a good thing? <br /><br />Which leads me to another ?. Are 3 compression rings the norm on a 2 stroke engine. I know in the automotive world we only have 2 compression rings, and only 1 of them is designed primarily for compression sealing. The other is mainly for oil control. There is a lot of talk about compression getting trapped in between the top and second rings and causing the ring pack to flutter and loose a lot of compression in a running engine. But that is on 4 stroke automotive race engines which see really high loads and high cranking compression above 200 psi. It may not apply to the two stroke. Anybody know??<br /><br />Thanks for any help.
Yepblaze
Re: More 1956 evinrude ?'s
Being as "those" motors had no fuel pump to begin with, that would be a retrofit installation.<br /><br />The rings are good pretty much good for the life of the motor.<br /><br />Back in those dinosaur days you should be lucky it's got rings at all. Just kidding, but you should run it rather than try to explain why the earth revolves lefty loosey.
Chinewalker
Also, make sure you keep her on a steady diet of oil-rich fuel. I run 24:1 in all my 1950s motors, using Evinrude oil and 89 pump gas. 87 may be okay in some areas, but it can be junk gas in others...
horsefly38425
i have a 35 bigtwin and the f p does have vac on it but i think it is on top cyl if it is a fuel problem and you have elec pump handy just hook it up and try her out i been thinking about one myself to avoid prop down the road or i mean river ;)
Neptune
Hi Jonboat,<br /><br />You may have seen posts here regarding 2 line or pressure fuel tanks. These were used instead of fuel pumps on the early Johnsons & Evinrudes (before 60-62?). Converting to a fuel pump system could be done in a couple of ways. As opposed to what you have, another method was to use a 3 nipple fuel pump (no longer stocked to my knowledge) with a fitting tapped into one of the intake covers and a tube running from this fitting to the vacuum nipple on the pump. Conversion to a fuel pump makes use of one of the less costly conventional fuel tanks possible with the older engines.
oldboat1
on a fuel pump conversion, will have to make sure the air outlet at the carburetor is blocked off (from the old two-line connection).
