mooring ball in a small lake
brownies
Re: mooring ball in a small lake
If it's two feet deep and the block is one....might the boat swing around and the hull hit the block?
Johnshan1
The only way that could happen is if the lake turned bad, with 1-2' waves right near shore, it could happen but I havnt seen it on this lake yet, hardly seen a white cap. something to keep in mind though.
paulie0735
Might also pay to check with whom ever has authority over the lake, some authorities are no longer allowing this type of practice.
Johnshan1
What type of practice?
paulie0735
The sinking of weighted objects as mooring's
RubberFrog
Originally posted by Johnshan1:<br /> The only way that could happen is if the lake turned bad, with 1-2' waves right near shore, it could happen but I havnt seen it on this lake yet, hardly seen a white cap. something to keep in mind though.
Seems like it wouldn't take much of a breeze to blow the boat right into it? :(
Johnshan1
Well the boat has a draft of about 4" and if theres a lot of wave action it wont be over the blocks, it will be 10' away.
Johnshan1
Just called the town about this whole deal, they dont care what I do, they have no code regarding anything to do with boats. I think I like my new town.
MrBill
Call your local concrete dealer...chances are that those located near lakes make 'mooring covers' every day with any excess concrete left at the end of the day. For shallow areas like you're in, concrete dealers make 5" thick round covers about 48 inches in diameter, with one or steel loops attaching chain. They settle into the lake bottom so that they don't stick up and get hit by props...the settling in also makes them stable and not moveable unless they're freed up or lifted with a crow bar. Just like an anchor, it isn't just weight that keeps them in place, although they're about 300lbs, you can roll them out to where you want it. Myself and all my neighbors use these, two adults can walk (roll) the mooring into place. Mine is in 4 feet of water, and occasionally get shifted by ice so you may need something that can be relocated easily.<br /><br />Use the correct tool for the application...round steel mooring caps are also sold. Skip the engine block or other massive piece of junk notion that would be near impossible to move or remove when necessary.
dajohnson53
What an excellent idea - the round flat mooring cap. I can imagine making one pretty easily if they weren't sold locally. I'd probably use reinforcing mesh, although I think 5 inches of good concrete is not likely to break up. A roughly round mold (masonite?), set the eyelet so it wont' pull out of the concrete - or maybe just set a tube through the center so later a through-bolt SS eyelet could be added. I don't know if the normal bags of concrete mix are good for under water, but I imagine that question could be answered.
