mooring a 900lb, 14' boat w/o spring lines?
gavdawg
Have a rather naive question. I am in the process of purchasing a small jetboat. I wanted something small, that my wife would feel comfortable with. Is it feasable to moor a craft such as this without spring lines? It is a small, light boat.
The only reason why I am asking is due to the positioning of the cleats. I personally am used to larger craft, where they are more or less manditory.
tpenfield
Re: mooring a 900lb, 14' boat w/o spring lines?
Usually you moor with a bow line and the boat swings in the breeze.
Are you referring to docking the boat?
gavdawg
Yes. I am referring specifically to the act of docking. I tend to use the term "mooring" to refer to docking. I Am aware that it technically is an inappropriate use of the term... but it is kind of hard to get away from it having heard it since childhood :)
Home Cookin'
"mooring" is not limited to tying to a mooring bouy. But obviously the OP is asking about mooring at a dock or a piling, perhaps a dolphin, or a combination of same. Let's call the place he ties up "the slip."
Whether one uses a spring line is not a function of the size of the boat, but the configuration of the slip. As you know, the object is to tie up so no part of the boat touches any part of the slip's structure, through any tide height or wind direction. Typically, the larger the boat, the more lines are needed to hold it off the various structures of the slip. That's where the spring lines are more likely to come in.
When contact cannot be avoided, or for temporary and supervised mooring, fenders, rub rails, etc. come into play, but it is not the best practice.
So for small boats, you can usually manage to configure your mooring lines with just the bow cleat/eye and the two stern cleats/eyes, adnyou can sometimes run a spring line off a stern cleat to a midship's cleat on the dock. No one here can advise you how to moor your boat in your slip unless they have been there.
Spring lines keep the boat from moving side to side or front to back. They are not usually mandatory for a slip, but if tieing up along a dock, using whips, they are necessary to keep the whips functioning properly.
sasto
Typically a boat that size is tied up (in my marina) using only 2 lines. The boat sits diagonally in the slip. The bow is tied up to the port foreward piling/cleat.......the stern to the starboard aft piling/cleat. Or visa versa.
Do I make any sense? If not I'll take a pic.
