ABFishin69
Thread starter- Joined
- Feb 2, 2007
- 5
All,
Thanks so much for all of you info. I have a quick questions I wanted to ask you all. I am looking at purchasing a 10hp "Moky Ward" Sea King 10hp - it's a 70's model and through research I believe is built by Chrysler. Through inspection, it's been sitting of course but pumps water in a tank, shifts in both gears nicely, rev's but has an occasional miss and then goes smooth again. I am guessing it needs crab work although this will be my first project. I am just looking for a simple motor to run on a restricted lake on occasion, and may use on a bigger boat as a kicker in the future. It's about 100.00 bucks right now and seems okay to me. I was curious to your guys thoughts. It will need some work but do you think with usual maintence I can keep it running. The only expereince I had with outboards was a 1985 johson 140 VRO and had no real problems other than a fuel pump. Just wanted to get your thoughts on the motor and possible work that will be invovled with the miss or sputter. Oh, the sputter did go away once it was running for awhile. I know this is limited info but I don't own the motor yet. Thanks!
