Monterey oil in water
Mark Innes
I have recently purchased a Monterey 276 over here in the UK!
Engine is Volvo penta 7.4GL ( Carb) and is used in fresh water.
I notice that the boat is putting some oil out in the water while at tick over in the Marina.
I have recently fitted a thermostat (not fitted previously) which has brought the operating temperature up to around 120 F from a previously undetectable temperature on the gauge. I thought the low temp was causing an over rich situation, hence the oil in water. This is obviously not the case as the oil is still there :confused:
Any ideas ?????
Thanks in advance
Mark
mkast
Re: Monterey oil in water
Perform a cylinder leak down test on the engine, it should show any problems.
bruceb58
A cylinder leak down test won't show what you need to know. You need to pressurize the water passages to see if there is a crack in the block
mkast
He states the engine is putting oil out into the water, not into the oil pan.
Mark Innes
I don't think I have water in the pan. The oil level drops gradually over time and I can see no signs of water residue in the oil filler caps.
Are ther other ways of checking???
Could It be the oil cooler???
Mark
Mark Innes
How would I check the oil cooler for leaks?
I know that mine is a complete unit with no removable element. Not a cheap item either!!
Would I have to drain the oil and water system and how would I check the oil cooler itself ???
Sorry! .........Lots of questions!
Mark
mkast
As the hoses are taken off , plug that hose. After the cooler is removed, pressurize the oil part of the cooler. Listen for air leakage.
bruceb58
Could probably pressurize either side and listen. I would pressuirize the side that is easier.
Mark Innes
Thanks very much guys!
I'll give it a go.
Great Forum by the way!!!!!:):):)
Mark
