modern coil wires?
dvanhout
1962 18HP johnson. pulled a coil and noticed bad corrosion on the end of the wire. of course I'm replacing the coil, points, condensers and the wire. my question is, can I use modern day wires,boots, and ends?
Honorary Supreme Mariner
That is an excellent motor and it needs 7mm metal core plug wires available at any boat shop.
dvanhout
thank you. I actually hit the junk yard and found a second one. bottom end is missing but the powerhead, carb and entire top end is in great shape. cost me $75. if anyone needs parts i have some.
