were to find model # and serial# in mercruiser 350HP motor
M medeica Cadet Joined Jul 12, 2010 Messages 6 Jul 13, 2010 #1 were to find model # and serial# in mercruiser 350HP motor
Bondo Moderator Staff member Joined Apr 17, 2002 Messages 71,357 Jul 13, 2010 #2 Re: model # Ayuh,... If the block is original, the ID tag is riveted to the starboard side, down low, aft on the block... If not,... You'll need to give Us somemore hints...
M medeica Cadet Joined Jul 12, 2010 Messages 6 Sep 8, 2010 #3 Re: model # The only thing I found was on the rear port side on the engine block by the bell housing: GM 5.7 J202 the valve casting:1409617 it's a two bolt It's a GM 350 that's all I know.Thank you.
Bondo Moderator Staff member Joined Apr 17, 2002 Messages 71,357 Sep 8, 2010 #4 Re: model # Ayuh,.. So what's the Question,..?? It's a 350cid Chevy.... If ya need Merc parts,..?? tell Us what this 350 is surrounded by... What drive,..?? got a #,..?? What vintage boat,..?? What's the Question,..??
