OBJ
- Dec 27, 2002
- 10,161
Re: Model number angst apology
Chris, if this is an electric shift, you will want to use "Premium C" gear oil. It's made for electric shifts. Or, you can use any gear oil that says "For Electric Shift" on the container. Don't use anything else.
Make sure the battery connections are clean from battery to starter.....including grounds. Dirty connections can cause the "click" only problem.
It may be also that the brushes in the starter may need a change out but first check out all other possibilities. Did you cross the big posts' on the solenoid with a screwdriver? If the starter cranks when this is done, it's likely the solenoid is bad.
