Mix ratio 1957 Elgin 12 HP
luv2b0at
What's the oil mix ratio for a 1957 12 HP Elgin 2 Cyl?
JB
Re: Mix ratio 1957 Elgin 12 HP
Almost sure to be 24:1, L2B. I certainly wouldn't use anything leaner without documented instructions.
steelespike
My period service manual says 16:1, 8oz per gallon.You might check with the boys at www.aomci.org they may be able to tell if its safe to run at 24:1.
luv2b0at
Thanks steelspike.
