Missing under power
ntmsheepdog
I just rebuilt the carb on my 1973 20hp Johnson outboard. It is running basically the same as it did before I rebuilt it. It idles great, runs at the higher speeds great, but inbetween when trying to get up to speed it feels and sounds like it is only running on one of the cylinders. Once it gains rpm it evens out and runs great. I have adsusted the carb several times both in a tank and at the lake. Same results. I would like it to run well at the slow to intermediate speeds for trolling and short distance crusing. Can someone please help?
Honorary Supreme Mariner
Run with a timing light and see if you can isolate the " miss " to one cylinder.----Was there any other trouble shooting done other than to assume that the carbureter was at fault ?
boobie
Or if you don't have a timing light, when it starts missing, pull one plug wire at a time and see if you can nail it down to the bad cylinder.
boobie
If it was jumping out of gear, wouldn't you get a "clunk" ??
ntmsheepdog
I didn't discount other problems but thought I would start with the carb since it was inexpensive and fairly easy. Where do you think I should start racerone? I do have a timing light.
I don't think it is jumping out of gear since I have had that problem before and went through the lower gear box. All is good down there.
boobie
Put the timing light on each cylinder when it acts up. Turn the timing light around and look into it. When you see black spots, that's where the miss is.
