1991 90hp Johnson. Have had it a couple of years. Doing maintenance this spring and found out it had no thermostats. Talked to the previous owner and he said the dealer's shop had removed them in 1994 while working on an overheat problem. The motor runs great, has 125lb compression in all cylinders, running 50:1 mix with VRO disconnnected.<br /><br />The thermostats have been out 8 years now. Should I be concerned about no thermostats, or just continue to run it as-is?<br />Thanks for your time.
