Hi, I have a 85 merc 140 hp 4cyl.. The problem is when it gets hot @ higher speeds it misses and falls on it's face when I use the trim..There is a slight miss without the trim but not nearly as bad..New plugs, cap, rotor, points..Alos valve noise, sounds like spark det from bad gas but put a tank of 93 oct in it..boat did sit alot before I bought it..Thanks any help would be great..l feel it may be a coil...
