Miss firing Merc 7.4 mpi L29 2000 2855 Ciera SB
dubs283
Batch fired injectors. I'd be looking for a broken wire (or solder joint). Don't forget to check the negative side too
A continuity test on all related wires/leads/connectors for injectors to ecm based on the wiring diagram posted is what I would do....
Magonsterz
achris / dubs​
thank for the 411 and attachments, will start running down lines and see where the glitch is if any, hopefully a wire and not a driver issue.
Magonsterz
update, pulled intake, hooked up fuel pressure gauge, hooked up injector pulse test unit and bingo, 3 failed to pulse and one was intermittent with weak fuel pressure discharged volume.
Remaining 4 discharge pressure drop were within 1.5 psi of each other.
Fixing to send into injector clinic since they did pass coil continuity test average 12.4 to 12.7 ohm, spec states 12.1 nominal resistance.
with any luck will be back on the water by august after some pre planned traveling is done.
Magonsterz
got injectors back from RC injector service out of Torrance, Ca. today and they were able to save all 8.
highest flow cc was 251.0 lowest was 250.0, avg 250.4 system balance is .4
4 were found to be dripping
2 had poor flow
2 had bad patterns and sub par flow.
plan to put them in over the weekend and fire that pig up.
Magonsterz
UPDATE, BACK ON THE WATER AFTER A LONG BATTLE
The guys at GML Motorsports located in Bakersfield, Ca. do not shy away from boat repairs of any year make or model.
If anything, they welcome the challenge, with Years of combined experience in all aspects of the automotive and marine field they were able to diagnose and resolve my issue where as two other supposed “specialty boat repair” shops FAILED.
Jesus and Lance at GML have grown the Motorsports Garage to work on all sorts, jet ski, boat (any size), two stroke or four stroke, motor cycle, compressors, tractors, diesels, well you name it.
So, my 2000 Bayliner with 7.4 MPI, MEFI3, BRAVO set up started surging one day. I like any other gear head dove into as many forum as I could, read everything I could get my digital hands on, tested, NO CODES at all not even one, swapped out everything, no luck, finally took the GML for the win.
They were able to trouble shoot multiple things, the heads valve guides were shot out, not detected by the leak down test and compression was decent, not great with 300 hrs on it but decent enough to be ruled out.
After head were off decided cylinders looked a little more scuffed than I would have liked apparently the previous two owners never kept up on the maint which made a lot of sense once I pulled manifolds, etc.
Had engine rebuilt to .030 over, using waaay better internals than stock materials, better rods, pistons, lifters and a mild cam upgrade. Lance himself took care of this service in house.
Once back together they found I had bad new replacement injectors, had original ones serviced and swapped back in offending units, which led to finding injector driver was shorted out and shooting fuel into engine as soon as key was on.
Maic Salazar Diagnostics was able to repair circuit on Mefi3 ECU, Bob at OBD Diagnostics was able to reflash with an upgraded tune, so with it up and running the mystery, no code throwing surging was gone. Time for a sea trial, ran great for approx 45 min then it pulled power, felt like limp mode, but fortunately the guys at GML were on the water with me that day and were able to diagnose. Apparently the “marine grade” plug wires were failing, the spark was burning through the boot, arching on the manifold causing the engine to pull timing. GML recommended MSD solid core wires, cut to length wires and the high temp boots, once installed second sea trial went as planned. 2 hrs on the water rowing through the rpm band at various levels, cool down and restart cycle, top end and bottom end with load cycles, winner winner chicken dinner.
I am sure I am leaving plenty out as this dynamic duo went the extra mile to fix this 30 foot express cabin cruiser where two other supposedly pro boat shops failed. If you need it done and done right the first time take it to them, I could have save myself a bundle had I done so the first time around not to mention the down time.
