Misplaced Connector
alanwp
In the process of replacing my 4.3 GL PEFS power steering actuator I removed engine parts for access. After installation I found this loose cable and connector hanging behind the engine. The engine compartment is extremely tight and can't find where it goes. The wire colors are red blue & tan. Please help!
Alanwp
alanwp
Re: Misplaced Connector
Thanks Guys - I'll trace the mating plug back from the relay
alanwp
I've been back to the boat (between the thunderstorms) and verified I have power to the 10A relay fuse from the 50A breaker. The connector I show in this thread also has 12V power. The trim/tilt wiring diagram Don posted on 7/2/11 shows connector B to the trim switch and it sure looks like the one I posted. If this is correct, there has to be a mating male connector to the remote control. I'll be 78 tomorrow and perhaps it's showing! Thanks, Alan
alanwp
Resoved. Traced line from remote to engine compartment. Found connector stuck and hidden between exhaust bellows and power steering actuator.
Don S
What did it go to?????????
