Misfire at WOT
Concepra
1998 Johnson 90 hp V4.
Misfires at WOT... doesn't do all the time, usually an hour, half hour after running great.
I've change plugs, stats, checked coils with ohm reader, have great spark and compression.
Can't figure out why is it doing this.
next step is to rebuild carbs.
Anyone have any idea what can it be?
emdsapmgr
When key ignition components on your engine (coils, stator, power pack and timer sensor) get old, they get weak. A normal age/duty cycle fact of life. These weak ignition components do not respond well to heat. So, often these components will work fine, when the engine is cold, or is just warming up. When the engine reaches normal operating temps, that heat is just enough to cause any of these above components to start to fail. You need to be troubleshooting these components from a factory manual, or from the CDI troubleshooting guide at this website: cdielectronics.com. The information here is excellent. Tricky to find fault with components which work when cold, but start to crap out once the engine warms to normal operating temps. My 79 85 hp would run great for about 45 minutes, then start to occasionally misfire. A gremlin to find for sure. Many of these ignitions require a special "peak-reading" voltmeter-not commonly available in most households.
