Engine is misfiring. Has rough idle not running on all cylinders. I have changed plugs and checked for arching on plug wires. I found some arching on one of the plug wires. I was told by the dealer that genreally the put a rubber sheath around the plug wire to fix because the plug wire is part of the coil. I was told the coils rarely go bad on these engines. I put the sheath over the wire but no change in condition. I then replaced that coil anyway with no change again. Engine will not get up on plane and runs rough. Shouldn't be a fuel issue. I changed fuel lines and all filters a year ago and use ethonal free gas. Problem started with a slight rough idle in no wake zones but would get up on plain with no issues. I went out the other day and had same slight rough idle but once I tride to get up on plane, engine totally started misfiring. Now it will not stay running and smells like its running rich.
