MinnKota Edge bow mount trolling motor 70 lb thrust
asiipring
Hey folks, Help a newbie out here if you can. I have a 24ft pontoon with a fishing deck on it. I am very anxious to install a trolling motor on her and start doing some great fishing. I have found a very good used trolling motor. It is a Minn Kota Edge bow mount trolling motor 70 lb Here is some additional info on motor. "Minn Kota Edge trolling motor I used only 5 times. 52" shaft. It's an awesome trolling motor but it's too long for my boat and too powerful. It jerks my boat left and right at the higest setting. I almost fell a couple of times. I have the original box. Cost me over $550 brand new bought at Gander Mountain. Cabela's is selling them for $635.
My question is this... Is the shaft too long for my pontoon? That is really it. Thanks for your help!!
Asii
Silvertip
Honorary Supreme Mariner
Re: MinnKota Edge bow mount trolling motor 70 lb thrust
The shaft can be shortened, or you can buy a shorter shaft from MinnKota. You do realize that the 70# thrust is a 24 Volt motor so you will need two deep cycle batteries wired in series and a two bank charger to keep them charged. Your pontoon engine will not keep up with charging duties if you had that in mind.
asiipring
i have purchased a seperate 24 v battery already. I can purchase a charger and be good to go right? all i do then is connect the troll to the batter and the battery to the charger and away I go! let me know if i am missing something!!
Thanks for the info
jtexas
You'll have to charge it on land with a 24V charger. minn kota says the prop shaft should be about 9" underwater, plus 5" in rough water. Did you want foot- or hand-control?
tashasdaddy
on a toon the motor need to be lower, than standard. the shaft depth should be adjustable, on the motor mount. and you will need 70 lbs to move that toon, they are hard to move side ways. i tow a disable one about that size, was the hardest thing to control my boat, with that thing in tow.
Silvertip
Ummm. You said you bought a 24V battery! If it's a single battery, I'd be interested in knowing the details. If you mean you have two 12V batteries you are good to go. I hope you know the difference between "batteries in series" and "batteries in parallel". Shown below is how two batteries are wired in "series" to deliver 24V to the trolling motor. It also shows how to connect a two-bank charger". As was mentioned, you need to plug the charger into a 110V AC outlet at the dock to charge the batteries. They do not charge from the engine alternator.
star18
I realize I'm digging up an old thread....anyhow I just bought a similar trolling motor - Minn Kota 70lb Powerdrive V2 24V and was wondering how to charge my two 12V batteries wired in series. So the above photo is how it's done with a two bank charger ???
There is no need to disconnect/switch-off the jumper between the two batteries to prevent a short circuit?
Silvertip
No. That's why they call them two-bank chargers -- or three bank, or four bank. These are essentially totally separate chargers in a single housing.
WARNING: If you try to buy something used, make darned sure the charger has isolated outputs -- as in separate pairs of wires for each battery. If there are multiple HOT leads but only ONE GROUND lead you do not have isolated grounds.
