Minnkota 80 Thrust
jww8882
I left the trolling motor down and tried to put in on the trailer. I goosed the engine and the trolling motor got hung up. I was able to get it up by lifting boat front end a little. Didn't appear to be damaged. I put the boat on the water the next weekend and the motor funs fine but the foot pedals do not work right at all. It is like the the pedals are broke,,,, Can't steer well at all and it does not work move the motor easily and the pedal is tough to negotiate. Do I junk it?
Silvertip
Honorary Supreme Mariner
Re: Minnkota 80 Thrust
Why junk it? At least remove the covers on the head and see what you damaged. If all looks well there, look at the foot control. When the motor struck the trailer it probably twisted the motor and broke or bent something in the head or foot control. I take it this is a cable steer and not an electric steer motor.
DuckHunterJon
You may have bent the shaft. It wouldn't take much of a bend to bind it up. Pull it off the boat and inspect it. Lay a straight edge across the shaft. I'll bet it's bent just enought to cause it to bind. If it's not crumpled, you may be able to bend it back. Slow pressure applied to the bend area is better than yanks. Good luck with it.
