I bought a used Minn Kota 74V at a garage sale it has a plug with
Red, Black, and Yellow wires on it. Is this a 24v red and black wires, and where does the yellow wire go or do.
PROBLEM WITH THE MK 40AT.
The shaft will only turn 1/2 way. Not sure what could be causing it all of a sudden. We were out on the water & it just quit on us. If anyone has any ideas I would love to hear from you! B4 I tear into it!!
You should be able to get a copy of the owners manual from the Minn Kota Website and download it, or give them a call, I am sure they will give you the answer real quick.
You have a 12 vot OR 24 volt motor meaning it has a selector switch that allows you to operate the motor on 12 OR 24 volts. Normally, red - black is 24 volts. Orange-black is 12 volts. For 24 volt operation you need two batteries in series. The orange wire goes on the POS terminal of the first battery (the one with the jumper between the POS terminal on BAT 1 and the NEG terminal on BAT 2). Some motors are just the opposite where Orange-Black is 24 volts and Red-Orange is 12 volts.
